Knowledge Base Extension - Upravená verze (modified version)
Extension phpBB 3.3.x
Jedná se o vlastní modifikovanou verzi Sheer Knowledge Base.
Modifikace nejsou finální a další budu postupně doplňovat.
Články, kategorie a nastavení z původní verze rozšíření budou zachovány
This is a custom modified version of Sheer Knowledge Base.
Modifications are not final and I will add more gradually.
Articles, categories and settings from the original version of the extension are not affected
Obrázek for contributors and developers / pro přispěvatele a vývojáře
Obrázek
  • Download from Obrázek
  • Tested on phpBB 3.3.14
  • Update/clean PHP code
  • Optimization compatibility for Php 8.3.x
  • Other small fixes
Obrázek
  • ACP
    Changes in the settings of allowed extensions (php backend)
  • Posting
    Adding attachments correctly offers only allowed files (window)
  • Other small fixes
  • Code Warnings and Quality Inspection
  • Fix typo
Obrázek
  • This version contains bug fixes and improvements
  • phpBB 3.3.x is now fully supported (the extension was tested on phpBB up to 3.3.4)
  • Fixed compatibility issue with Prism JS syntax highlighter extension
  • Optimization for Php 8.x
  • Reorganization of php code to handle ACP
  • Updated jquery plugins and other java scripts
  • All html files in style folder are twigged
  • Removed text links e.g. print, comments and replaced with buttons
  • Other minor changes in the display of articles
  • Updated language
  • Modified notifications
  • The description is also optional
  • Rewritten configuration management (does not use the kb_config table)
  • Rewrite search backend
      - Knowledge Base MySQL Fulltext
      - Knowledge Base Native Fulltext (default)
      - Knowledge Base PostgreSQL Fulltext (test version)
  • New option to add a prefix for selected forums and posts
    This replaces the hardcoded text [ Knowledge Base ] in the title,
    but does not affect those already created. The title must be manually edited.
  • Other small fixes.
Prosím, před nasazením na produkční fórum rozšíření otestujte.
Please, test the extension before deploying it to the production forum.
Show Spoiler
knowledgebase_2.0.1-RC3.zip
(267.52 KiB) Staženo 821 x
knowledgebase_2.0.1-RC1.zip
2022.04.03
(265.09 KiB) Staženo 661 x
knowledgebase.zip
2022.03.23
(264.02 KiB) Staženo 709 x
Vrátit se na „Rozšíření - phpBB 3.3.x“
