First of all thank you for the SXG Explorer Software. Its one of the best pieces of soft for this devices.
Two things:
1. Maybe you should offer an english Forum here
2. I use the same software on 2 different computers (same versions etc.) With one it works fine... with the other I get an error message when it retrieves the phone infos. It says: " 'X,' is not a valid integer value " while X is an "8" (mostly) or a "9". I think it comes when the signal strength is retrieved.
Thaank You and more...
- sutrus
- Administrátor
- Kontaktovat uživatele:
Perhaps exactly I don't understand. You can in more detail describe problem.
I don't know much well English. Carry on such forum isn't reasonable. If but will about forum focus establish new branch.
Program meanwhile isn't in extenso functional and completed, but step by step completion new function
edit:
Yet remark,
my native forum is http://siemensmania.cz/forum/viewtopic.php?t=24679 and there's based branch for this programme.
In addition users he can speak English and is here more possibility consult problems
edit:
Yet remark,
